Hi all,
I'm looking for a little bit of help connecting my Beovision 3 with a newly-purchased Beomaster 5500. I'm simply trying to get the TV sound through the amp & speakers, and vice-versa to get radio through the TV.
Using the information I've found so far, I've connected them up as below, using a 1611 Beolink Converter:
BV3 - ML Cable - Type 1611 Beolink Converter - 7 Pin DIN (PowerLink Socket) - Tape2/AUX (Beomaster 5500)
In theory, this should then work - using either a Beolink 1000 or Beo4, the BV3 switches on and goes to Sat/TV, and the Beomaster goes to AUX, but no sound comes out of the linked device. I'm using [AV] [SAT] [SAT] for example to get this far.
Could anyone give me some guidance as to what I need to do to get this sorted?
Thanks in advance!
Mike
