Latest post 10-11-2011 5:19 PM by Dan Ludington. 9 replies.
Page 1 of 1 (10 items)
  • 10-10-2011 4:20 PM
    I'm looking for a FM Antenna for my Beomaster 4000
    Hi friends wondering if anybody can help with this issue I cannot find a FM dipole antenna for my Beomaster 4000,it has the two prong hook up and a place to to attach it to the back. I can't find one for sale anywhere,where can one be found,I'm sure this is a common item thats missing like the presets cover,but what should I do? I won't get any stations except for one. Dan
    Dan Ludington
  • 10-10-2011 5:47 PM In reply to
    Re: I'm looking for a FM Antenna for my Beomaster 4000
    I use a 40 Cm long cable strip connected to the 75 ohm middle pin with an alligator clip, works like a charm
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 10-10-2011 6:12 PM In reply to
    What is a cable strip and where is the 75ohm middle pin.Hmm
    Dan Ludington
  • 10-10-2011 7:28 PM In reply to
    Dan Ludington:
    Give me 3 min. and I will post a photo, the antenna is difficault to find. New ones does'nt exist.
  • 10-10-2011 8:13 PM In reply to
    Sorry had to eat, here pics
    Connect here
    Alligator clip, clamp
    Cable strip
    All clear Laughing
  • 10-11-2011 12:10 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Seller "lazerwave" on Ebay sells an FM dipole for Beomasters.  I've bought 3 of them for my BM1900, BM2400, BM4000.  Make sure you buy the right one - he sells both male and female connectors.  I think I paid $9 for each one - don't remember if that included shipping.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 10-11-2011 12:19 PM In reply to
    Rich:
    I have bought from him as well. Good stuff.
    I *believe* he will also fab to spec.
    • B&o bottle opener
  • 10-11-2011 4:16 PM In reply to
    I have bought a few from lazerave they are great,I wonder if my set has the male or female plug,how can you tell,but thanks Soren I see what I can do to at least try it.
    Dan Ludington
  • 10-11-2011 5:14 PM In reply to
    Rich:
    Link ??
  • 10-11-2011 5:19 PM In reply to
    Heres a link.
    http://www.ebay.com/itm/Bang-Olufsen-Type-FM-Antenna-w-PAL-Female-Connector-/160655432064?pt=LH_DefaultDomain_0&hash=item2567cf5980#ht_732wt_1398
    Dan Ludington
