What to do with it when it's done ?
I haven't asked myself that question and I wouldn't know what to answer.
Maybe someone wants it, maybe I will keep it. Maybe I will have to make room for another project.
Maybe it will never be finished and if it does, it will most likely not be 100% original - even
if the finding of this second cupboard allows me to bring it very close.
I am looking forward to playing some records on it, that's the primary goal for now.
Off with the baffle.
It's very clear to see that this is an original 38RG baffle.
2 identically sized holes for the needle cups, one larger hole for the needle dispenser,
a smaller hole with perimeter marks from three small screws for the tonearm base
and the remains of a large cutout where the gramophone deck once was.
The latter has been partially filled to make the new leather sit nice and tight.
The dial glass still sits, untouched, with its original wooden fasteners and frame.
