Latest post 10-08-2011 3:27 PM by Vienna. 1 replies.
Page 1 of 1 (2 items)
  • 10-08-2011 1:33 PM
    How to check software/HD-ready status of Beovision 7-32 (Mark 3)
    I'm having a load of trouble getting my BV7-32 Mk 3 to display an HD image.
    Is there a way to definitively check, via means of diagnostics/software versions etc. if the set is capable of doing this?
    Thanks!
    Jonathan
  • 10-08-2011 3:27 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: How to check software/HD-ready status of Beovision 7-32 (Mark 3)
    jkhamler:
    As already posted in your other thread:
    The 4 digit TYPE NUMBER would help ...
    You can find this number:
    1) on the rear side of your tv (hidden under the cover for the connectors)
    2) by entering the service menu
