        1st March February 2012
	    Latest post 10-08-2011 5:15 PM by  Leslie. 8 replies.
								        10-06-2011 9:32 AM
									        Leslie
								                - Joined on 05-07-2009
								                - Netherlands
								                - Posts 2,201
										    I did something stupid with my 2nd AV7000 and I'm not gonna tell you what
Lucky man as I am I just blow the thermal fuse which was hidden inside the transformer.
What I would like to know is what kind of thermal fuse do I need to replace regarding temperature. There are so many, but what's the safest fuse I can use. Thank you! Btw, the unit has been modified from 110 to 230Vac!
									    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
									        Ferdinand
								                - Joined on 05-04-2008
								                - Malmö, Sweden
								                - Posts 159
										    Re: Technical advise please
										    Hi Leslie,
Well tell us what happened ... have you also been modified from 110 to 230Vac!   Is that black connector thing (seems a bit roasted) where your finger was? ...
Sorry I can't be of any help with the thermal fuse question.
									    BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
									        Leslie
								                - Netherlands
								                - Posts 2,201
										      Ferdinand:
Hi Leslie,
Yes,, I have seen the light, thank you for reminding
Okay, I will explain my stupidity, but I'm a bit embaressed to tell  Anyway, I have followed up @Die Bogener's advise but forgot to read his explanation, so I left all wiring as it was en connected the blue link as an extra (see thread). So I made a short circuit in one of the circuitbreakers of my house and blew up the thermal fuse of the AV7000. I have rewired the red AC wire by bypassing the thermal fuse but I still don't have any power on the transformer. Sh1t, I thought it was only the thermal fuse that got defect. Hope someone can give me some advise what could be wrong. I don't have any schematics of this unit.
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Forgot to tell, the picture as seen on this thread, is how it should be (except for the roasted fuse)!
									        Beobuddy
								                - Joined on 04-18-2007
								                - Posts 1,582
										    Just start to measure things.
Here's probably a thing to consider:
									        Beobuddy
								                - Posts 1,582
										    Check met een ohmmeter of de windingen nog wel heel zijn (grote kans).
Verder moet je je wel realiseren dat trafoos op in een bepaalde manier zijn gewonden.
Als je de bij de ene kant  van de trafo een stroom richting kiest die tegengesteld is van de 2e winding rechts, dan heffen de opgewekte inducties elkaar op.
Zoals uit jouw foto is op te maken, is het linkergedeelte van de trafo in tegensgestelde richting van de rechter aangesloten.
Jouw thermische zekering doet hier volgens mij niets, behalve een deel kortsluiten, wat niet wordt gebruikt.
Juist met het 110V origineelin je achterhoofd hebbende, ligt het juist voor de hand om voor 230V beide windingen links en rechts in serie te hebben.
Dus :
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Precies wat ik zelf ook in gedachte had Beobuddy. Helaas houd mijn kennis op hierna op. De twee spoelen in serie zetten is me nu duidelijk. Wist alleen niet dat de manier waarop, nog van invloed kon zijn op de werking. Ik zal het zo gaan aansluiten zoals door jou getekend, alleen op de inkomende voedingsdraden aangesloten op de trafo (rode en zwarte draad) daar meet ik geen 220V! Dus moet ik het op de voedingsprint gaan zoeken. Enig idee welke waarde thermische zekering (temperatuur) ik moet gaan gebruiken? Dank in ieder geval dat je de moeite hebt genomen het een en ander te verduidelijken via de foto! Zeer gewaardeerd!
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    De thermische zekering loopt in serie met de rode 220V draad dus als die er uit ligt zal de trafo ook geen spanning krijgen toch?
De windingen zijn gelukkig nog ok, (15 ohms elk) op de primaire kant.
        Page 1 of 1 (9 items)
