1st March February 2012
Latest post 02-03-2012 9:50 AM by chartz. 68 replies.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
chartz:
No news from Axel...
Patience my friend, I think he will take note of this thread. If not I can surely help you....
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
chartz
- Joined on 07-20-2009
- Burgundy
- Posts 984
Just got mail!
Axel will send me a new one for comparison. We'll see.
But for him the photos are normal.
Leslie
- Netherlands
- Posts 2,201
Well then, if the new one sounds better you should keep that one
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Rich: Perhaps 30 degrees too far CCW.
Compared to my SMMC 4 and org. MMC 4, yes about 30 degrees to much.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Put it this way - if someone was asking advice on whether to buy this cartridge using your last photo as evidence of condition, I would definately tell them to forget it.
I think we should also say that this isn't at all typical of Axels work & shows that we are all human & prone to mistakes - if indeed this turns out to be the case.
Chris.
Leslie
- Netherlands
- Posts 2,201
Søren Mexico:
Hi Søren, long time, where have you been? Like your avatar
Søren Mexico
- Mexico city
- Posts 1,621
Hi Leslie, stole your avatar and changed it to my like, many years ago we had a logo with "Build Printing Machines, Not Rockets"
I was out 2 weeks working on a 40 tons m/c where I would rather like to work on my BM 4000, got parts but no time, the only thing that disturbes me in this life, is that I will have to work to make a living.
Going out again for a couple of days, province, limited internet. No forum no fun, just work, I'm suffering.
Leslie
- Netherlands
- Posts 2,201
Right on! But I've changed mine (another mood now). You're logo is or was quite funny, I like that kind of humoristic advertising. Hope you're doing well and don't suffer
chartz
- Burgundy
- Posts 984
Here you can see the front was glued askew:
A better view of the problem:
Leslie
- Netherlands
- Posts 2,201
Quality issues?
Søren Mexico
- Mexico city
- Posts 1,621
chartz:
Hey don't you like my cat?
We love your cat, any news from Axel, even I can see that the needle angle is totally wrong
chartz
- Burgundy
- Posts 984
Søren Mexico:
Any news from Axel, even I can see that the needle angle is totally wrong
News yes but comments, no!
He's sending me a new cartridge for testing. He hasn't seen this thread I suppose. Anyway, since everybody here says he gives sterling service I'm confident this issue will be solved. I have other cartridges to repair! This one was a test.
Phil Hunt
- Joined on 12-30-2007
- NW NJ USA
- Posts 92
"Can't say I've noticed any of these problems - except the long cantilever. Can't use the flip-down stylus protector, as the stylus won't fit inside it!"
Not wanting to pile on Axel, but how could the longer cantilever be right?
Besides differing significantly dynamically and (likely) changing the characteristics of the cart (lower specific output and resonance come to mind), at minimum, the the tangency goes off a little and the stylus guard becomes useless and possibly dangerous to the stylus assy.
And, as a reluctant edit-
I am a Soundsmith customer. I couldn't be more happy with his carts.
Also, as a small business owner, I know how cruel the internet can be. I would hope that any criticism of Axel has integrity, and am hoping Axel will resolve any and all in the public domain, a win for all.
chartz
- Burgundy
- Posts 984
I can confirm the low output problem.
As regards Axel, I'm sure this is a one-off, and I will be more than happy to report back positively. The aim of this thread was really to know whether my cartridge had a specific issue. That's also why I did not create a new topic!
Found this: http://forum.beoworld.org/forums/p/30060/239054.aspx#239054
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
I have just inspected several MMC4's that Axel has done for me and they would appear to have the same problem visibly. However, the sound quality would appear to be good.
The phenomenon is not apparent on MMC2 and MMC3 which all appear quite "normal".
I noticed a problem with the MMC4 because the arm lift is only just sufficient for the stylus to clear the record!
I will report the matter to Axel.
chartz
- Burgundy
- Posts 984
Leslie:
I'm still waiting for the new cart to arrive.
Thanks for checking Graham, with one seriously warped record, I noticed the same thing... I was fast enough to stop everything before the disaster!
Anyway, the angle of the stylus is odd, and it doesn't sound too good to be honest!
I'm thinking MMC2 re-tip then.
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Should be exactly the same, all MMCx models are the same apart from the cantilever and diamond.
My two retipped MMC2's, the retipped MMC6000 with shibata needle and the retipped MMC5 with essentially MMC4 specs (done by Axel about a mong ago) are all playing well at the time of writing.
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
joeyboygolf
- Posts 3,252
chartz:
Leslie:
I have had an overnight reply from Axel which I reproduce here:-
Hi Graham,
thanks for the info.
It has crept a mistake. I will use for all MMC s with the error make a free repair.
I apologize to all my customers for the inconvenience.
Best regards Axel
Leslie
- Netherlands
- Posts 2,201
joeyboygolf:
chartz:
Leslie:
Hi Graham,
Best regards Axel
There are more? Anyway Jaques, let us know how it ends. Got a load to repair...
chartz
- Burgundy
- Posts 984
Hello!
I have just discovered that someone here in France does B&O re-tips!
I had missed that one. Maybe because since the demise of the Revue du Son I haven't read any other mags than the excellent Hi-Fi World (I'm a 20 year subscriber!).
I'll have to give them a ring to know whether they also renew the suspension. I'll keep you informed.
HERE
They even re-manufacture belts for B&O equipment for heaven's sake!
THERE
