My Beogram 4002 has started to exhibit some speed instability (slowing) during play. It doesn't play steadily slow, but seems to fluctuate, slowing slightly (but very audibly) then returning to normal. I eliminated belt slippage or motor capstan slippage as the problem, so it seems that its some poltergeist in the electronics. The innards of the deck look absolutely unmolested, and there are no visible clues as to the source of the problem. I don't mind replacing caps or other electronic components, but I am hoping to get some direction on where to start. Any help or advice will be much appreciated. As would words of encouragement.
Cheers, Kevin
