Latest post 09-28-2011 1:51 PM by Eugenio Colazzo. 4 replies.
Page 1 of 1 (5 items)
  • 09-28-2011 3:54 AM
    VOLTMETER RV7 - RESISTOR VALUE
    Hello
    I need help, in my new voltmeter I found a burned resistor, if someone has the value (first band seems to be brown) could tell me the colors?
    Maybe a service manual... :)
    Thanks in advance
    Eugenio
    Eugenio Colazzo
    Filed under: ,
  • 09-28-2011 10:57 AM In reply to
    Re: VOLTMETER RV7 - RESISTOR VALUE
    Eugenio,
    Can I suggest you unsolder the resister because the coloured bands may be visible underneath the resistor.
    Regards Keith....
  • 09-28-2011 11:17 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    I have a RV7, too. I managed to find a parts list and from the internet. I'll try to find it again and post a link.
    EDIT: That wasn't too easy! Here is the parts list. I am not quite sure about the resistor in question, the PCB layout shows there should be two resistors, R1 (10 ohm, 0,33W) and R2 (0...220 ohm, 0,33W) connected in parallel, whereas in your photo there seems to be only one resistor (but visibly a place for the second).
    The site itself also has some more B&O test-gear manuals. Could somebody ask if the site's keeper would allow those manuals being added to Beoworld's manuals section, too?
    Bang & Olufsen - The art of controlling sound, picture and light
  • 09-28-2011 11:35 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    I also find a photo of the insides or my RV7. Unfortunately the photo is not especially a good one, but clearly there is just one resistor, too.
  • 09-28-2011 1:51 PM In reply to
    OMG!!!
    Thanks to all! Thanks thanks and thanks again and again!!!!
    Tryed to remove the resistor but was not readable. Thanks for the image and the doc above.
    I'm so happy!!!
    Best regards!!!!!
    Eugenio
    PS
    Today is a great day, first the manual, and then for the FIRST warranty destructable label from MV!!!!
    Eugenio Colazzo
