Latest post 10-01-2011 4:55 PM by mirralph. 3 replies.
Page 1 of 1 (4 items)
  • 09-27-2011 4:10 PM
    beo5 confyg.tool fails to load
    dear members,
    i have installed 3.87 in windows 7 professional.
    however, following the log in en marking offline field, the following message is dysplayed:
    Loading..........
    The programm fails to progress.
    Do you have a solution.
    Greetings,
    Mirralph
  • 09-29-2011 2:41 AM In reply to
    Re: beo5 confyg.tool fails to load
    Mirralph,
    The programme not start in the manner you have described can have many causes.
    Is this a new Windows 7 Professional installation or is it being used without problems with many other programmes ?
    If it is not a new Windows 7 installation, then it is likely that there is conflict with something else running. The first thing I suggest you do is reboot the windows system and re-install the Configuration Tool without any other programme running and then try again.
    Regards Keith....
  • 09-29-2011 9:47 AM In reply to
    • Rolf
    • Not Ranked
    • Joined on 04-21-2007
    • Stockholm, Sweden
    • Posts 63
    These are the symptoms when trying to start the Config tool in a 64bit version of Windows 7 which is (still) not supported by B&O. The easiest workaround is to use the XP Virtual PC options within Windows 7 and install the Config tool within this shell. This works well although it is a little hassle to remember to connect to the BEO5 USB post within the XP emulator.
    It does save on having to operate a seperate XP laptop/PC solely for B&O !
    //Rolf
  • 10-01-2011 4:55 PM In reply to
    Thank you for your help.
    My problem is solved
    Greetings
