1st March February 2012
09-27-2011 10:06 AM
Laursen
- Joined on 12-30-2010
- Aarhus, Denmark
- Posts 17
ConfigurationTool 4.11 on Windows 7 and MacBook Pro
I used to have an old XP PC, which now has gone to the eternal Microsoft heaven, the PC was among others used to configure my Beo5.
For some reason trying to run the CT4.11 on Windows 7 Ultimate (32bit) on my MacBook Pro doesn't seem to work, the software won't load any configurations at all, and importing a CTX file is possible, but I can't access it. There is no serial number in the list so I can't get in touch with the configuration at all.
Any help would be greatly appreciated.
Beovision 10-40 DVB-T/C/S2, MX5500, BeoSat, MX4000, BeoMedia 1, BeoCord
VX7000, BeoSound Ouveture, BeoGram 3500, BeoLab 11, BeoLab 8000, BeoLab
3500, BeoVox CX30, BeoLink 1000, Beo4, Beo5, BeoSound 2, BeoCom 6000,
BeoCom 1401, BeoTalk 1100, Beolit 606
Larskoelle
- Joined on 10-03-2010
- Munich
- Posts 246
Re: ConfigurationTool 4.11 on Windows 7 and MacBook Pro
I do not have the config tool but I am also using some virtualisation technology for running Windows on my MacBook. Unfortunatelly I still need Windows for my tax declaration once in a year...
Well, the only problem I can imagine that you do not have a usb connection to your BEO5.
Lars
Beo Time, A8, EarSet3i, EarSet2, BC2, BC6, BL3, BL11, Apple TV1, BEO Ballpen, BL2000, BL3500
Christmas 2010 Prize Draw 1st winner. BeoSound 9000 Mk3
Thank you
Laursen
- Aarhus, Denmark
- Posts 17
I do have the USB connectio, and the Beo5 is recognized, however on the PC it was not a problem to setup the Beo5 without having it connected to the PC, only when the changes was to be uploaded to the Beo5 it had to be connected.
As it is now on the MacBook Pro, I can't even get to do anything in CT.
/Niels
Bart
- Joined on 04-16-2007
- Netherlands
- Posts 128
Did you try the XP-compatibility modus?
Page 1 of 1 (5 items)
