Latest post 09-27-2011 12:59 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 09-26-2011 10:45 PM
    beogram 8002 tonearm
    hey everyone,
    i just recently bought a beogram 8002 and i love it! this ques has probably been answered already-sorry if it has... but the one issue im having with the TT is the tonearm wont move when i push the < << and >> > buttons...any insight on what the problem could be? and what i can do to solve? any help/advice would be MUCH appreciated.
    Thanks!
  • 09-27-2011 1:11 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beogram 8002 tonearm
    Welcome to Beoworld !
    Will the platter start rotating when you press < (PLAY) ?
  • 09-27-2011 12:20 PM In reply to
    hey martin,
    Yes the platter does rotate when i press play and the tonearm does automatically cue the stylus tip in the first groove of the record as it should. I am getting sound, however, if i then want to choose a specific selection on my record, the TT doesnt respond to me pressing the << < and > >> buttons...
  • 09-27-2011 12:59 PM In reply to
    • Dillen
    • Posts 5,008
    Check the lamp inside the black plastic casing at the backside of the front panel.
    I can supply a correct lamp if needed.
    Presing < while playing activates the repeat function (indicated by the LED on the sensor arm flashing).
