I just get the remote control :) I use it with the battery included but I was unable to get the light on (always off for me). So I change the battery and at first, nothing, and now the light is blinking but is very fade... strange.
Did you have the Beo4 Cinema manual? I thought the key Cinema was the one to use in order to bring the light, but it seems not.
cheers,
sergio
