Hi there,
Could you please help me with the following:
- which IR Eye version is this ? It has 6 connectors (3x2) on the back, and the common "Timer, up, down, Play" buttons
- will it work with Beoport ?
- if so, which connections to use to connect it to the 3.5 jack ?
Thank you
