Hi all,
does anyone have the codes for the following setup?
Twin tuner sat receiver Cubecafe 420s
Benq w600 beamer
Cheers,
Kevin
Hello Kevin,
I am assuming from your comment that you want a Beo5/6 XML file to control these two products ?
I do not have the IR codes for these products, but if you have the original remote controls, the codes can be captured.
Regards Keith....
