Latest post 07-10-2007 4:46 PM by The Plumber. 6 replies.
Page 1 of 1 (7 items)
  • 07-09-2007 3:46 AM
    • simonbring
    • Not Ranked
    • Joined on 04-23-2007
    • Stockholm, Sweden
    • Posts 29
    • Silver Member
    Beolink 5000, Beo4 wall brackets or table stands
    Hello,
     Do anyone of you know if B&O made any wall brackets for the Beolink 5000 and the Beo4?
    Thanks,
    Simon
  • 07-09-2007 4:05 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beolink 5000, Beo4 wall brackets or table stands
    Yes, they are around £20.
     Weekly top artists:
  • 07-09-2007 6:55 AM In reply to
    note :  they look very simular but they are'nt ! the wall bracket for the BL5000 is slightly deeper...............
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 07-09-2007 4:29 PM In reply to
    • simonbring
    • Not Ranked
    • Stockholm, Sweden
    • Posts 29
    • Silver Member
    Ok! I never reflected over hte possibility to find it in a B&O store.. I will take a look! Did npt find any on Ebay, only or beolink 1000....
  • 07-10-2007 1:16 AM In reply to
    I have 2 wall brackets for Beo4 at home, one in my bedroom, the other in the guestroom, they're quite affordable & well designed.
    As for  table stands, I designed mine using a BeoCom 9600 table charger ....recycling art!
     I can't attach the picture because it says you can't do it with Firefox..
    Reunion Island is greeting you!
  • 07-10-2007 3:10 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Chris. If you email your photo to me at   andytulloch@supanet.com    I'll stick it on this thread if you like.
    Andy T.
    Poor me, never win owt!
  • 07-10-2007 4:46 PM In reply to
    You can get a table stand for the Beo4 from HERE
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
