Hi
I am considering a BeoMaster 6500/7000 in order to get more available inputs and be able to play my old vinyls. However, I would like to keep using my BeoSound 9000 as the cd player. Obviously I can just hook it up with AUX out on the BS9000 (in option 0) going to the CD in on the BeoMaster, but I would loose the ability to control the CD player with a remote control
So I was wondering if it would be possible to hook into the datalink signal intended for the CD player from the BeoMaster, and feed it to the BS9000 via its MasterLink port? Perhaps simply using a ML converter 1611 in between the CD port on the BeoMaster 7000 and the ML port on the BS9000?
Does anyone have any experience with such setup, or knowledge if it would possibly work. I dont have a BeoMaster to try it out with.
Jesper
