Latest post 09-30-2011 9:41 AM by Søren Mexico. 3 replies.
Page 1 of 1 (4 items)
  • 09-24-2011 6:15 AM
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Another Beogram 6500 problem
    Now my Beogram 6500 will not stop spinning!  Plays records fine and arm returns to "home" position but the turntable will not stop turning.!!! Unless you pull the plug out . It does not start turning though when you plug it back on though.  Anyhelp anyone?
    Regards Sandy
  • 09-25-2011 1:21 AM In reply to
    Re: Another Beogram 6500 problem
    Check and clean the the 2 contacts 1S1,1S2, at the same time clean and lubricate all mecanics, check Start/Stop on the front panel
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 09-26-2011 12:51 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Thanks for the advice, today i opened up the machine, and poked around a bit. Tried a record and it now stops again!!  I have not actually sorted anything but for now i will see how it goes.
    Regards Sandy.
  • 09-30-2011 9:41 AM In reply to
    Clean all old grease and lubricate all moving mecanical parts, carefully with a strip of paper wettet with iso alcohol, clean the contacts, check the manual and check the adjustment part and lubricating chart.
