Latest post 09-23-2011 2:16 PM by a11mcr. 6 replies.
Page 1 of 1 (7 items)
  • 09-21-2011 7:14 PM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Help with connection problems??
    Hi all, just got my second pair of penta 2`s but cant get them to workSad i have a BS2500 so i have connected one pair to one powerlink socket (in series) and the other pair to the other powerlink socket, all cables are ok and all displays come on but no sound from one pair (display shows two dashes where the volume is).
    Anyone have any ideas please let me know?
    Kind Regards, Mark
  • 09-21-2011 10:51 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Help with connection problems??
    Ok, I've been thinking about this one for about an hour or so and all I can come up with is that it could be a MUTE issue. That's the best answer I can come up with, but it doesn't really make sense as all Powerlink sockets are muted together, or so I think.
    Evan
  • 09-22-2011 4:04 AM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    I don't own the Pentas, just an idea: To which position is the mode switch set on the non working pair of Pentas? (Page 11 of the user guide)
    hfat
  • 09-22-2011 5:27 AM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks, tried the mute button but no luck just cuts out the working pair, both pairs are set to audio on the switch?
    Kind Regards, Mark
  • 09-22-2011 6:20 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Do all Pentas power up when you press CD, RADIO...?
    Did you try to change PL sockets? What happens when the second Penta pair is connected to PL socket 1?
    Did you try to daisy chain all four Pentas?
    Did you change Powerlink cables?
    Hope this helps
    Stefan
  • 09-22-2011 4:32 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Right, tried swapping the plugs over on the 2500 but still the same, the pair at rear work but front one dont?
    i cant daisy chain them as the cables wont reach.
    all penta displays light but only two amps switch on (the one that the sound comes from) the one that dont have two dashes where the volume is?
    now i do have a powerlink to speakerlink converters so tried these on the non working ones and i get faint sound, and get the volume number displayed, but when i press mute the sound is still on?
    this is now starting to annoy me Super Angry
    Kind Regards, Mark
  • 09-23-2011 2:16 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Right i moved them around and daisy chained them and they work but when using both powerlink socket on the 2500 they dont?
    but still both sockets on the 2500 only switch one pair onAngry
    Please i need help urgently!
    Kind Regards, Mark
