Latest post 09-22-2011 7:02 PM by kai. 7 replies.
Page 1 of 1 (8 items)
  • 09-19-2011 8:08 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Bang & Olufsen Speakers with Other Tv
    Hi
    Somebody I know has a beovision 7-40 which has developed a fault with the screen it requires a new LCD, he has been quoted and he feels at 85, that he is not wanting to pay the price what would you use as a replacement tv, non bang & olufsen
  • 09-20-2011 2:25 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Bang & Olufsen Speakers with Other Tv
    And?
  • 09-21-2011 7:28 PM In reply to
    • kai
    • Posts 81
    I do not mean anything against b/o products I worked for a dealer for 17 years and have met many people who I can call customers and friends. This one individual customer, has now reached an age where he is not wanting to buy another b & o set, but would like to use his beolab speakers and subwoofer, in the set up with a non b & o tv, I was just wondering if that would be possible :)
  • 09-21-2011 7:55 PM In reply to
    • Evan
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Very possible. But, you will need a new audiomaster. Most common (and currently popular) way to do this is to use a non-B&O receiver. Onkyo seems to be the choice around here, but anything with volume controlled pre-outs will do just fine.
    Connections will be made via mono RCA cables, you will have to set the speakers to line-in mode.
    P.S. Just make sure what ever panel/videomaster he ends up with has an audio output of a form compatible with your new audiomaster. Lately, flat panels manufacturer's have been skimping on this area and only incorporate only one type.
    Evan
  • 09-21-2011 7:57 PM In reply to
    Best thing would be the flat screen connected to an amplifier with line outs for active speakers, and from there to the speakers, I use a bigger Onkyo, but a small one will do if its only for TV sound and 5 channel, you will have to check which type of subwoofer can be connected.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 09-21-2011 7:59 PM In reply to
    Hi Evan, same thoughts same timeLaughing
  • 09-21-2011 8:00 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Good man Søren! Wink
    Evan
  • 09-22-2011 7:02 PM In reply to
    • kai
    • Posts 81
    Thank you for the replies, I will have a look at the onkyo amps :)
