Hi C,
the BL 3500 receives the time from the main system, but only if the main system has an integrated clock. Because the BV 10 has NO clock, you can´t display the correct time on your BL 3500 (and you can´t use a play timer). So you have to set the display of your BL 3500 to NO CLOCK.
Regards
Räuber
