What is wrong with your BEO 4?
Is it the Lcd?
Or the circuit board?
Or Both?
You can buy the Lcd or You can buy a new circuit board for the BEO 4. Comes with new Key Pad as well,then you just have to open up the remote and do two solder joints then your done.You will have a as new BEO 4.
Easy to do as i have done afew times.
Just don't touch the new strip on the bottom of the lcd with your hands.
Hope this helps?
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
