Latest post 07-09-2007 3:59 PM by The Stig - ver. 1.7. 3 replies.
Page 1 of 1 (4 items)
  • 07-08-2007 10:26 AM
    BeoSystem 3 + Format
    Hi
    How can I set my default format on my BeoSystem. I almost always have to change to Format 3 everytime I change channel - which is very annoying. Is there a way to have Format 3 as my default Format for all channels?
     Christian
  • 07-08-2007 1:48 PM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    Re: BeoSystem 3 + Format
    You can deselect autoformat but this does not change the situation . According to my knowledge this is a feature, you can not change it. Hopefully enough people report this to B&O to get a sw fix.
  • 07-09-2007 2:57 PM In reply to
    I wonder if autoformat is not enabled - how can I check?
  • 07-09-2007 3:59 PM In reply to
    Hi
    Set marker on Setup then "Red" "Red" "GO" there you find it under  ADJUSTMENTS
    Check that Wss is ON also
