Latest post 09-14-2011 4:36 PM by Beolab1. 1 replies.
Page 1 of 1 (2 items)
  • 09-13-2011 12:23 PM
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    Chip related problems with BeoSound 9000?
    Hope another member can help me out. I took my BeoSound 9000 from the AV setup to play stand alone with only two Beolab1 speakers connected. I set the system in Option 1 and the system works as it should, also when using the Beo4 remote. One thing does not seem to work. I can't put up the volume.  Not on the controlpanel of the BeoSound 9000. Not on the Beo4. The display shows ''Volume 00'', but I can't put it up. The Beo4 I use does not have the specific ''BS9000'' configuration setting option that the old Beo4's had, this newer one has only configuration option ''Audio 1'' & ''Audio2''. Which one should I pick and how can I get the thing to play at a louder volume than 00? Thank you very much in advance for your help!!!
  • 09-14-2011 4:36 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Re: No volume control on BeoSound 9000
    The dealer checked with B&O product support and said t is most likely chip related. B&O Netherlands is going to service it. Has anyone else with a BeoSound 9000 ever had chip related problems?
