        1st March February 2012
	    Latest post 10-10-2011 1:03 PM by  elephant. 14 replies.
								        09-13-2011 8:09 AM
									        ajames
								                - Joined on 05-04-2007
								                - Posts 275
										    Hi - I don't know much about this, but basically I am looking for something that will play my Itunes library - in apple losseless and connect to a Beovision Avant without the need for any adaqptors, hopefully I would want to be able to see Album Covers and have an easy user interface, I can then get my Lintronic box to control it.
Is there anything out there that would do this quite cheaply or should I just invest in a newer iPod with greater capacity - my old one is only 30mb and operated through an Onkyo box with OSD and via the Lintronic. I just wanted to find out if anyone else has found a better way of doing this.
									    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
									        ajames
								                - Posts 275
										    Re: suitable media server
										    Main problem with that is that I can't plug it into my Avant easily and also I'd want the older one that stores the tracks on the hard drive within it. The other thing I looked at was a PS3 but I understand that the remote on that is wireless so I couldn't use a BEO4 controlled by the lintronic box. At the moment I can control the iPod from any tv that is on the ML system.
									        beojeff
								                - Joined on 11-29-2007
								                - Posts 543
										    There are adapters for the PS3 that can handle all the IR controls except for the on/off. Also, it is very easy to upgrade the hard drive in the PS3.
You might also want to consider some of the current blu-ray players on the market. I have a Samsung BD-D6700 that has an external hard drive connected to the USB port. It allows you to navigate the hard drive and control playback via the remote. It also has Netflix, Hulu, and Vuze.
I like the first gen Apple TV because the Avant can control it via its PUC. Even if the Avant hasn't been updated to have Apple Remote in the PUC, the Apple TV can learn the remote codes of another device that IS in the PUC.
									        ajames
								                - Posts 275
										    PS3 sounds quite attractive and I'm wondering if that can be controlled by the PUC as I seem to remember seeing Playstation on it as well as Apple? Do you know if it displays Album COvers - it would also be quite neat as I could use it instead of DVD1 and sell that to help with the cost
									        elephant
								                - Joined on 04-16-2007
								                - Melbourne, Australia
								                - Posts 2,215
										      ajames:Is there anything out there that would do this quite cheaply or should I just invest in a newer iPod with greater capacity
If you have limited cash, and you are trying to decide what will give you the "best bang for the buck", I would of thought expanding your "on the go" music collection with an iPod upgrade was the way to go ?
If you do get a new iPod you will still be able to use the Onkyo via the Linctronic ?
									    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
									        ajames
								                - Posts 275
										    Hi - yes a new iPod will still work with the Onkyo, but the graphics are quite limited and the newer stuff includes Album covers - on the other hand the graphics are only used to navigate and a screen saver comes on in any case after a minute
I think the PS3 sounds like a good idea - I hadly ever take my iPod out with me so portability is not that great an issue. It would be good if there was something that could also receive internet radio
									        elephant
								                - Posts 2,215
										      ajames:I think the PS3 sounds like a good idea
and you already have a PS3 ? or will you need to buy one ?
									        ajames
								                - Posts 275
										    I'd have to buy one - but my iPod is 7 years old and on it's last legs
									        elephant
								                - Posts 2,215
										      ajames:
touch choices :-(
the PS3 also gets you bluray but the Avant will not be able to take advantage of the resolution
PS3 also gets you games if that is important
if I was in your situation I would be looking at a second hand old generation MacMini or a second hand old generation Apple TV but that is because I would get more of those simple because I am not a gamer
my sons have their game equipment connected - but hardly ever use it
whereas our MacMini is used every second day
									        ajames
								                - Posts 275
										    Thanks, yes, I think maybe a an old Mac TV box would do it as I'm not that bothered about Games unless my nephew is visiting. And then wait until there is somehing available that gives music and internet radio etc (Can't afford a BS and BM5)
									        kallasr
								                - Joined on 04-19-2007
								                - Willich, NRW, Germany
								                - Posts 1,077
										      ajames:
LINK shows how to connect apple tv ....
Or - even better -  this one
Be sure to get aTV / Firecore
Ralf
									    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
									        Kokomo
								                - Joined on 08-21-2007
								                - Spain
								                - Posts 618
										      ajames:And then wait until there is somehing available that gives music and internet radio etc (Can't afford a BS and BM5)
The Apple TV 1 has internet radio capability.
									        ajames
								                - Posts 275
										    Hi - quick update to say thanks for the replies and I bought Apple TV 1 which arrived on Friday - I've ordered an HDMI to Composite converter as I couldn't get the hack to work.
Apple TV works fantastically well with the Avant, does everything I want and can be hidden away - it's brilliant and I'm very happy with it - so thanks again to everyone for the advice.
									        elephant
								                - Posts 2,215
										      ajames:Apple TV works fantastically well with the Avant, does everything I want and can be hidden away - it's brilliant and I'm very happy with it
good to hear that
here's wishing you many happy listening and viewing hours
        Page 1 of 1 (15 items)
