Latest post 09-13-2011 11:04 AM by ajames. 2 replies.
Page 1 of 1 (3 items)
  • 09-13-2011 7:59 AM
    Option Settings - Beolink Active and MC4002 in the same room
    Hi - I have both of these in the same room, once I purchase a longer Beolink cable I will move the active system into another and just have the beovision, but for the moment they are both together - which is a problem as I can get the TV picture through the link system and control through the Active, but the TV reacts as if it were standalone so pressing Sat means I get a picture but the TV changes channells whevere I scroll up or down.
    Is there a V.Opt I can select for the TV to avoid this and have it act as a monitor only - I can always set it back again later when the ML Cable has been installed.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 09-13-2011 9:52 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: Option Settings - Beolink Active and MC4002 in the same room
    How about deleting all the MX4002 channels apart from the one that your RF link is set at? (or do I not understand the problem?)
    Alternatively you could perhaps make your Beo4 a 'link only' remote (ensuring that the TV is set to a non-link option).  If you do this the Beo4 should only work the Active;
    Standby + List together
    Press List till CONFIG appears
    Enter 2002 , the display should read LINK ON
    Press Exit
    (Repeat to cancel)
    There's probably a better way to do this and I am sure that others will come up with better ideas, but how long does it take to get hold of an ML cable?
    Regards Guy
  • 09-13-2011 11:04 AM In reply to
    Actually, that's true, the cable won't take long but installing it will! - thanks for the suggestion - I will try that tonight
    Andrew
