Latest post 09-13-2011 1:18 PM by Herben. 2 replies.
Page 1 of 1 (3 items)
  • 09-13-2011 6:07 AM
    • Herben
    • Not Ranked
    • Joined on 09-13-2011
    • Posts 3
    Beolab 5 with Marantz AV7005 - balanced out connection possible?
    Hi, I would like to use my balanced out from my Marantz AV7005 pre-amplifier to my beolab 5 speakers.
    Does anyone know whether this is possible and suggestions on how to connect?
    Thanks a lot for help.
    KR Herben
    Filed under:
  • 09-13-2011 7:38 AM In reply to
    Re: Beolab 5 with Marantz AV7005 - balanced out connection possible?
    It might be possible but you need to see what the voltage output of the Marantz balanced outs are.  If more than I think 2.5, you have to make adjustments on the lab 5s.
    Beolab 5, beolab 3, beolab 4000, beosound 9000
  • 09-13-2011 1:18 PM In reply to
    • Herben
    • Not Ranked
    • Posts 3
    Thanks beoinbuff,
    Just checked and unbalanced out is 1.2V and balanced out 2.4V
    Is the 2.5V the max limit for the beolab 5 for input voltage? In that case no adjustments would be needed?
    Does anyone know whether XLR to Powerlink cable exists?
    How can I "power on" the beolab 5 speakers automaticly with my non B&O pre-amplifier (Marantz AV7005) or is this impossible?
    Thanks for picking your brains....
    Greetings,
    Herben
