Latest post 07-08-2007 7:43 AM by Roger. 1 replies.
Page 1 of 1 (2 items)
  • 07-08-2007 4:05 AM
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Does anyone have the pin-code to the real service menu for the BV 7-40???
    Does anyone have the "pin-code" to the real service menu for the BV 7-40???
    (Setup menu)
    Regards
    BL8000 MkII Black
  • 07-08-2007 7:43 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: Does anyone have the pin-code to the real service menu for the BV 7-40???
    I would ask my dealer for help here: You may alter the baseline settings for the screen, but these are given a range in the ordinary setup menu for a reason. Increasing "the light" (as you requested in another thread) could shorten the lifespan of the panel. I know most dealers are happy to guide you so that your BeoVision is correctly set up.
    And please beware that even the 7-40 mkII takes a long time to reach max backlight-level. Do you still think it is too dark after 1-2 hours?
    Roger
