Latest post 09-14-2011 1:08 PM by Ulf. 2 replies.
Page 1 of 1 (3 items)
  • 09-10-2011 10:00 PM
    Beolink 7000 Board schematic diagrams?
    Howdy,
      My Beolink 7000 remote is giving "no contact", but controls the stereo and light just fine.  It is not receiving.   My Beolink 5000 is receiving just fine from the same stereo.
      I have already replaced the 5 capacitors per other posts.  Any other ideas?
      Does anyone have the detailed schematics of the Beolink 7000 remote?  I need the schematic for the boards, which are NOT in the service manual on this site.  I have already downloaded that manual.
      Any ideas folks?
    Thanks,
    Seahawk
  • 09-11-2011 12:48 AM In reply to
    Re: Beolink 7000 Board schematic diagrams?
    Can you post a picture of your modification on the board. Pure interest. Had the same issue before using smd components (2 caps under the tin can) with still "no contact" messages. Have been using tantalium after and then it worked!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-14-2011 1:08 PM In reply to
    • Ulf
    • Top 100 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 665
    Use 2,2 uF 6,3 V.
    Good cleaning under the old caps
    Ulf
