1st March February 2012
Latest post 09-07-2011 10:52 AM by bayerische. 4 replies.
09-07-2011 4:55 AM
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Beosound 9000 MK II - as smooth as it should be?
I bought a complete B&O System (that I will not keep, I was just interested in the speakers - Beloab 4000 - that came with it, to replace the Beolab 2500).
It is a Beosound 9000 MK II.
When CDs are changing you can hear a very quiet noise: http://www.youtube.com/watch?v=7oeRMiK8sNg
Not nearly as bad as here http://www.youtube.com/watch?v=IK2z0-lEKhU&NR=1 , BUT - is it a fault or does it have to "sound" that way? I thought it had to work without any noise?
Thanks for your comments.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
archie
- Joined on 04-16-2007
- Paris
- Posts 497
Re: Beosound 9000 MK II - as smooth as it should be?
The sound of the first 9000 is ok
the sound of the second is not normal, maybe the 'contact' behind is not positioned on 'vertical position'.
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
First is OK, check the position options on the screws on tha back of the unit.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
kallasr
- Posts 1,077
bayerische:
Luckily the first one is mine
Position screws are in the position d) / flat on a table:
Thanks for your help.
Ralf
bayerische
- Helsinki, Finland
- Posts 3,593
kallasr:
bayerische:
Ralf
OK, good!
Then you don't have to worry. The BS9000 was never "silky" smooth. Could have been with a pneumatic system, besides the compressor.
-Andreas
Page 1 of 1 (5 items)
