Latest post 09-08-2011 12:57 PM by chartz. 4 replies.
Page 1 of 1 (5 items)
  • 09-06-2011 12:28 PM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    IR eye for Beosystem 5500?
    What kind of IR eye can I use for the Beosystem 5500?
    Is it possible to use a later IR eye, perhaps modified, like this one?
    Thanks!
    Jacques
  • 09-07-2011 5:27 PM In reply to
    Re: IR eye for Beosystem 5500?
    The original type was 2001 acording to the system manual for 1988/89 which I have in a original printed copy.
    It looks like the old MCP type tranciver panel but has only a send and recieve circuit installed.
    It should be connected via the SENSOR plug on the back of the BM5500.
    It looks like one used MCP tranciver panel which I got. Grey with just the word sensor to the left and Bang & Olufsen printed to the right. The plug has 6 pins and the cable is grey.
    I might sell it but it came with the very rare Beolink 1000 remote/code converter kit for BM6000/8000 which I still need a special cable for to be complete.
  • 09-08-2011 2:20 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Friedmett:
    I might sell it
    I, for one, would grab it!Smile
    Jacques
  • 09-08-2011 8:12 AM In reply to
    I thought you might. Smile
    Anyway I got no use for the code converter kit as its rather incomplete and Beolink 1000 option for BM6000 or BM8000 is not that important and I can wait for the day when a complete kit will turn up.
    This means that yes you can have it. I looked through the system manual and it does confirm that item: 8920010 is the correct sensor for BM5500.
    That is 4 fresh pictures taken with the system manual to confirm the right type. The bit in Danish says: Sensor Extra infrared send/receiver for Beosystem 5500. To be used when the Beosystem is placet in  an akward way in terms of remote distance like in a corner. Connection by 6 pin DIN plug.
    Make me an offer by pm.
  • 09-08-2011 12:57 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Friedmett:
    The bit in Danish says: Sensor Extra infrared send/receiver for Beosystem 5500. To be used when the Beosystem is placed in  an awkward way in terms of remote distance like in a corner.
    Exactly my case!
    Thanks Anders! Smile
    Jacques
