Latest post 11-05-2011 4:20 AM by TWG. 5 replies.
Page 1 of 1 (6 items)
  • 09-06-2011 11:54 AM
    Beolink pc2 and beolab 4000
    Can I connect Beolink pc2 to my PC Windows XP and listening musical files and internet radio trough Beolab 4000 without use Beosound?
    Filed under:
  • 09-08-2011 5:34 AM In reply to
    Re: Beolink pc2 and beolab 4000
    Hi, yes, you can use BeoPort / BeoLink PC2 as an audio master (set it up to option 2), as long as you don't have any BeoSound or BeoVision in your setup.
    You'll press CD to access the PC CD, NMUSIC for audio files & NRADIO for internet radio.
    Reunion Island is greeting you!
  • 09-08-2011 10:29 AM In reply to
    Thanks for your reply. I have an other question: Can i link Beolink pc2 to Beosound 3000 for listening net music?
  • 09-09-2011 4:11 AM In reply to
    Sure you can, in that case, BS3000 will be the audio master (A.OPTION 2) and BeoPort will be in option 6, if they are in 2 different rooms. If in the same room, BeoPort connected to BS3000 via Masterlink will be in option 0 and you can get rid of the extra IR eye.Smile
  • 09-11-2011 5:44 AM In reply to
    Do you advise me to add a beomedia 1 even if I do not have a B & O TV?
  • 11-05-2011 4:20 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    - Can I use the Beolink PC2 / Beoport as a standalone unit without Masterlink?
    - How does it behave in a Masterlinksetup with a Beosound 5 and Beosound 3000: When I want to listen to N.Music on a PC/Mac, too; will it work?
