lano:
If I connect the audio master (for exemple a Besound Overture)
to a Beovision and put it in a.opt 0 will it still be the audio master?
If not, is it then also possible to connect a Beoport in opt.0 to the Beovision and
controll everything via the Beovision and thereby distribute n.music to link rooms?
@1 YES - ATTENTION: an Ouverture as an audio master can NOT distribute PC sources like
Netmusic/Netradio to a ML system!!!
@2 NO - BeoPort needs an audio master like BSd 3000/3200/9000/4/... to distibute Netmusic/Netradio,
otherwise you can access these sources only locally.
