Latest post 11-14-2011 5:11 AM by PhilLondon. 3 replies.
Page 1 of 1 (4 items)
  • 09-05-2011 1:24 PM
    • lano
    • Not Ranked
    • Joined on 04-25-2010
    • Posts 66
    • Gold Member
    Linkplayer CD
    Hi, is it possible to use an old audio master (overture/bc2300 link converter) together with Linkplayer and:
    1) Have local control of the old audio master and play the CD on the connected speakers
    2) Distribute n.music to all linkrooms except where the old audio master is located (both Beolabs and Beovisions)
    3) Distibute the CD to all link rooms
    /Lars
  • 09-25-2011 4:36 PM In reply to
    Re: Linkplayer CD
    If you have a tv in the same room as the audio master, and all the speakers in that room are connected to the TV.
  • 11-13-2011 5:07 PM In reply to
    • lano
    • Not Ranked
    • Posts 66
    • Gold Member
    Re: Linkplayer CD
    Hmm, I'm not able to get this working. Pressing N.Music only sets the Beocenter 2300 in Tape mode. I currently have both the Beocenter and the Beoport in a.opt 0 and in the same room as the BV (with speakers connected to the BV). Am I doing something wrong or have I missunderstod what should be possible to do?
  • 11-14-2011 5:11 AM In reply to
    Re: Linkplayer CD
    You need the BV in option 2, the Beocenter 2300 in option 0.
    LinkPlayer in Option 0, with Vintage Audio Master option activated.
    All speaker must be connected to TV.
    One can only start N.MUSIC and N.RADIO with a remote.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
