Latest post 09-05-2011 1:25 PM by joeyboygolf. 6 replies.
Page 1 of 1 (7 items)
  • 09-05-2011 11:10 AM
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    mmc4 removal and way to test
    hi can anyone help with the removal process of the mmc4 cartridge? i guess its a gentle tug and it will be free from the arm, or is it? my stylus sounds like its permanently got dust on it, this i guess is a sure fire tell tale sign of a worn stylus tip. any ideas.......
    cheers
    jason
    (formerly nokinnikon from the old site)
  • 09-05-2011 11:24 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: mmc4 removal and way to test
    I wouldn't remove it simply to clean dust off - use a stylus brush. These cartridges are prone to losing coil contact with the pins if they are removed too often.
    If you really need to remove it then yes - a gentle pull should be all that is required.
    Chris.
  • 09-05-2011 11:32 AM In reply to
    With your left hand and 2 fingers, grab the TT arm (the one with the MMC) and hold it steady, with the other hand (right hand) and 2 fingers, grab the MMC and gently wiggle the MMC until it comes lose, then pull it straight out without bending the pegs. If you are lefthanded inverse the hands
    With a multimeter check the coils across the pegs.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 09-05-2011 11:36 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    Medogsfat:
    Chris.
    thanks. glad to see your still going strong on here medogsfat. i remember you from the old site!
  • 09-05-2011 11:37 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    Søren Mexico:
    cheers soren!
  • 09-05-2011 1:05 PM In reply to
    And here and read
  • 09-05-2011 1:25 PM In reply to
    Wiggle and pull Jason and send it to Axel here
    http://www.schallplattennadeln.de/
    Regards Graham
