If you have iTunes you can stream wirelessly your radios directly to the BS8 with an Airport Express and a RCA 3.5mm/Mini Jack plugged in both the BS8 and the Airport Express.
That's pretty simple, and works perfectly at minimum cost (Airport Express 89€ + RCA/Mini Jack 5€)
If you have an iPhone/iPad you will do the same directly from the Apple "Remote" app that let's you stream wirelessly music/radios to the BS8 (with Airport Express connected to the BS8 of course)
Hope this helps.
E d o u a r d G
- Beovision 10-40 Orange MkII / Motorised stand / DVB HD T2/C MkIII
- Beolab 5 Black
- Beosound 8 Black
- Beocom 2 MkII (Polished Alu)
- Earset 2
- Earset 3i
- Form 2 Black
- Beotime (Alarm Clock)
- Keyring
- Beo 6 / Wall charger
- Beo 4
°°°°°°° 2nd Prize Draw Winner - November '11 / Beolab 3000 N.O.S °°°°°°°
