Latest post 09-01-2011 5:14 PM by Leslie. 6 replies.
Page 1 of 1 (7 items)
  • 09-01-2011 3:59 PM
    • CJM1
    • Not Ranked
    • Joined on 09-01-2011
    • Posts 35
    BeoSound Ouverture tape deck jammed [:S]
    The tape deck in my BeoSound ouverture has given up the ghost. it has refuesed to rewind for a while. and now just never works. when it gets turned on it click and makes squeeking noises. Has anybody had theirs fixed before and how much did it cost? Unsure
    Filed under:
  • 09-01-2011 4:24 PM In reply to
    Re: BeoSound Ouverture tape deck jammed [:S]
    Many, some repaired by myself and most by my Beoworld member friend ipaul, and if your handy it wil cost you only the belt which is probably the cause and takes about an hour. The first one I had (before my virus began) was repaired by a B&O dealer and cost me around 150 euro'sSuper Angry. Now after approx. 15 units the belt is most of the time the issue. Very difficult to explain how to do it. Maybe ipaul is willing to give some instructions by text? He's the expert.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-01-2011 4:48 PM In reply to
    • CJM1
    • Not Ranked
    • Posts 35
    now that you mention the belt. it probabley will be. the squeek sounds familliar to as of the similar thing like a fan belt on a car. and it makes a whiriing noise aswell. im not risking taking my Beosound apart as i am no expert. i have been recommended by B&O a specialist who could probabley fix it for a price. and what do you mean by a virus?
  • 09-01-2011 4:53 PM In reply to
    CJM1:
    Addicted to B&O (virus)Smile
  • 09-01-2011 4:54 PM In reply to
    Sorry, you just joined the club, welcome!
  • 09-01-2011 5:00 PM In reply to
    • CJM1
    • Not Ranked
    • Posts 35
    thank you very much. i will admit i have the virus as well. been fairly lucky with my headphones and my ouverture which i aquired rescently. and i have been gifted a beovision avant which was about to be thrown out!! i have a technically skilled person who helps with electronics and he could help fix it. are the ouvertures hard things to open and fix or do they need to some skill. and how much will a belt be? and what are they made of?
  • 09-01-2011 5:14 PM In reply to
    Not that difficult, all screws on the back cover to be removed, then the lower board, after that the upper board to have acces to the tape unit which is fitted with 4 tiny screws. Probably Martin Dillen can supply the belts. I think he is reading all threads with the word "beltsWhistle?
