Dear fellow Beoworldlers,
I imagine this has been asked before so I apollogise for asking it again, but it's been a long while since I was on here last.
How do I connect my MacBook running Lion to my Beosound 3200 without loosing to much of the "quality" of sound.
Up to now I have been using the headphone socket but I have been told that is a big no no.
I am told I should use the Firewire because this does not take up any resources from the CPU compared to the USB port.
What are your suggestions?
Sadly I won't be able to enjoy the sound to much due to the neighbours so it does not have to be the platinum solution.
Any pointers greatly appreciated, Regards Toby
Kind Regards
Toby
I better do my bit and suspend my siggy.
