Latest post 09-10-2011 12:51 PM by rfc1. 9 replies.
Page 1 of 1 (10 items)
  • 08-31-2011 2:18 PM
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Beogram 6500 not worky
    Hi all, tried to play a few discs this evening ,but my beogram 6500 seems totally dead.... I have a full beosystem 6500 set-up  and all was fine about 2 weeks ago, every other component works ok. Tried the obvious like plug fuse on the beogram but still nothing. Any help anyone?
    ESP you Lee, as you sold me it, albeit 4 years ago.!!!!!!!
    Cheers Sandy.
  • 08-31-2011 5:16 PM In reply to
    Re: Beogram 6500 not worky
    There is an internal fuse on the power supply board which is prone to failure.
    If the deck is completely dead then it will be that fuse.
    Regards Graham
  • 09-01-2011 2:33 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Ta Graham, is it a full stripdown to locate Fuse??
    Sandy
  • 09-01-2011 3:26 AM In reply to
    Just two screws to open the deck and the fuse will be revealed!
    Regards Graham
  • 09-01-2011 4:21 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    OK thanks.
  • 09-01-2011 1:37 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Got the fuse out, guessing its the right one its got colored lines on it.
    can i just check it with a continuity tester?
    Is it ok to try the beogram with silver paper round the fuse to check operation?
    Sandy
  • 09-01-2011 2:29 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    rfc1:
    Sandy
    Yes, you can check the fuse out of circuit with a continuity tester. It should have full continuity.
    NO, it's absolutely NOT ok to wrap silver paper, alu foil or anything else around a fuse, it's there
    to protect your Beogram, your house and you.
    A fuse blows for a reason and, ideally, you should check that reason before fitting a new fuse.
    However, a fuse can blow for what looks like no reason, usually from a voltage surge or burst and
    it will be ok to fit a new fuse and try powering up the Beogram again.
    If that fuse also blows, there is DEFINITELY something wrong that needs to be repaired.
    Shorting a fuse will just cause something else - somewhere else - to burn.
  • 09-01-2011 3:01 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Point taken Martin, i will get a new fuse.......I see that there are different types of fuse available , i need a 500ma 250v one but it seems that there are different  "blowing" points of fuse available, can someone tell me which type to buy?
    Thanks again Sandy.
  • 09-01-2011 4:36 PM In reply to
    According to the service manual a slow one T500mA. Must be confirmed by others to make sure.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-10-2011 12:51 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Finally got some new correct type fuses today, ............It lives again, thanks to all  who helped.
    Sandy
