PerroMal:
Reference here is to Audio System Only.
I have a Beocentre 9000 in the central room.  This ML equipment has its AV output connected to an ML/MCL converter.  The converter feeds an MCL network to several link rooms.  Each of these rooms has either X-Tra Speakers or X –Tra Active Speakers kits installed.
I currently have a problem.  Whenever the remote  (any B&O type) stand-by  (red button) is pressed in any link room, it also shuts down all the link rooms being used.  This switches off the ML/MCL converter in the central room causing this situation.  The Beocentre 9000 in the central room is not affected if that is being used at the same time.
I have tried putting all the various options into the eyes associated with the each speaker kit in the link room but cannot overcome this problem.  I would appreciate if someone could offer some advice?
I assume you got a BS9000 in your mainroom - BC9000 has no ML connection- and ML-MCL converter is connected to the Masterlink connection.
The ML-MCL converter is the amplifier for all your linkrooms  The MCL system is a passive linksystem using speaker level output signal of the main system or an ML-MCL converter. MCL2 AV is a bit different. Changing volume in one room will change volume in all rooms, pressing STANDBY will set the ML-MCL converter to STANDBY = all linkrooms are standby.
Set all linksystems to L.OPT 1 (audio only).
To set one single MCL (passive) link room to "standby" just press MUTE.
To set al link rooms to STANDBY press STANDBY.
To set the whole system (incl. BS9000) to STANDBY press long STANDBY.
Stefan
