Latest post 08-21-2011 11:54 PM by Chrisreunion. 3 replies.
Page 1 of 1 (4 items)
  • 08-20-2011 10:46 PM
    Beoport
    I am doing my head in re this technology! I am told to scan music from PC which will automatically go to Beoplayer (NetMusic) Should it also scan my Itunes which I have purchased.  If not, how do I get them onto playlist on (NetMusic)?
    Filed under:
  • 08-21-2011 3:08 AM In reply to
    Re: Beoport
    Hi, BeoPort will scan each hard drive separately, by pressing Ctrl + S, you can choose which drive your want to scan.
    Then BeoPort will add all music files to NMUSIC, wherever they are in the drive, and as long as the sound format is handled by B&O (MP3/MP4/WMA), that excludes ALAC and DRM files of course.Smile
    Reunion Island is greeting you!
  • 08-21-2011 8:02 PM In reply to
    Re: Beoport
    Thank you for your help. The B&O guy told me over the phone it was possible to transfer my Iphone library to NMUSIC. How can I tell if my Iphone library is protected by ALAC and DRM?
    I have a Windows Vista PC. Thanks
  • 08-21-2011 11:54 PM In reply to
    Re: Beoport
    Hi, all you have to do is launch a scan (Ctrl + S) of the hard drive where your Itunes library is located.
    If the files can be played by BeoPort, they will be added to NMUSIC library, otherwise they won't, it 's very simple and automatic.Smile
