Latest post 07-12-2007 4:35 PM by Max. 5 replies.
Page 1 of 1 (6 items)
  • 07-07-2007 1:08 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    BeoCom 1401 base, Help me :(
    I was fiddling with my 1401 base and i ended up taking the lid off of the thing. I looked for a service manual b ut couldn't find one, does anybody know how to get the thing apart?
  • 07-07-2007 1:22 AM In reply to
    Re: BeoCom 1401 base, Help me :(
    There is no service manual only a user guide and I have never had the need to take the base part. What is the problem you are trying to resolve ?
    Regards Keith....
  • 07-07-2007 4:21 AM In reply to
    • Dave
    • Posts 2,328
    I'm trying to get behind the battery compartment to get the pins back in place so that the lid opens and closes properly (I accidentally knocked the lid off it's pins), I'll keep trying, and thanks for the reply, i just don't want to damage it!
  • 07-07-2007 7:24 AM In reply to
    • Max
    • Not Ranked
    • Joined on 04-19-2007
    • Devon
    • Posts 64
    I have a BeoCom 1401 and didn't know there was a battery in the base unit. My handset connects straight back to the phone socket and doesn't seem to have a need for battery power, the base just supports the handset and holds some post it notes. Are you sure it's a 1401 - does it look like this http://www.beoworld.org/prod_details.asp?pid=427?
    My B&O is in my Bio.
  • 07-10-2007 6:31 AM In reply to
    • Dave
    • Posts 2,328
    sorry, yes it's certainly a 1401 but the compatment is a 'dummie'... look behind the post it notes and there is a flap that opens to the left. there resides the compartment where batteries would go - in the beotalk 1400. i just bought a beotalk base and i wanted to swap the lids because my 1401 base has the current bang and olufsen logo... call me compulsive ;)
  • 07-12-2007 4:35 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    Ah, I see. Sorry to question your post - I have never seen a BeoTalk 1400 before. If it was still available I may have bought one instead of a BeoCom 1401 & BeoTalk 1200. Happy fiddling, and I hope you end up with the solution some time soon.
