Latest post 08-25-2011 7:03 AM by TWG. 9 replies.
Page 1 of 1 (10 items)
  • 08-15-2011 4:18 PM
    Beotime question
    Is there any way to set the alarm on the Beotime to turn on a device such as the TV without the alarm chime in the the Beotime also sounding?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 08-15-2011 5:30 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beotime question
    Razlaw:
    Has been discussed & answered in this thread:
    http://forum.beoworld.org/forums/t/39983.aspx
    Filed under:
  • 08-15-2011 6:01 PM In reply to
    Thank you.
  • 08-17-2011 1:14 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    To quote the above linked thread,
    Vienna:
    "When the selected alarm source switches on, you will also hear the sound of an
    ordinary built-in alarm to make sure you wake up."
    Big Smile i'ts not a bug, it's a feature ...
    Who else has decided against a BeoTime because of this? I've been really keen on getting one of these until I read about that "feature."
    Sad
    Evan
  • 08-17-2011 6:02 AM In reply to
    To be fair the alarm is fairly unobstrusive and can very easily be turned off, I can't see how it is that much of a problem. However it would be nice to have an option to turn off!
  • 08-17-2011 11:46 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    I think it is a good feature: Even if your TV or Audio-System fails to start or simply in the case of a power loss in your house: The Beotime will ring and wake you up.
  • 08-17-2011 2:19 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    TWG:
    Ok, that doesn't make me so angry anymore. But I can't help thinking that will still be really annoying.
    Evan
  • 08-18-2011 1:21 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    I think it HAS to be annoying in some way: It's intended to wake you up and not to make you feel like "Ah, that's so beautiful and relaxing and zzzzzzzZZZZ!" Big Smile
    Personaly I like the Beotime: The Alarm goes off in the morning, music starts... I like it.
    The only real negative facts:
    - For a 300 Euro Alarm clock I insist on better quality control and 3 equaly backlit displays! I habe 2 Beotimes and you can see a slightly different backlight on both of them (e.g. 1 of the 3 displays is darker than the other 2...)
    - touch sensivity is not that great: The displays don't light up if you just slightly touch the Beotime... she likes it a little bit harder Wink
    For a B&O product this is not acceptable and if you want to be an attractive brand you should avoid those quality problems: A bad example, I know, but I don't think that a 300 Euro Apple Alarm clock would suffer from such problems becaus Apple (most of the time) DOES its homework!
  • 08-25-2011 12:09 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    TWG:
    Well I suppose you are right!! Not like its any different from my current routine!
    What happens now is that my cellphone wakes me up and I reach over to turn off the alarm and grab the Beo4 to play a CD or my iPod. I would really like to get rid of that first step!!! Laughing
    Evan
  • 08-25-2011 7:03 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Then go and get yourself a Beotime! :-)
    It can even control the light when you activate the secret menu of that thing ;-)
