I have an mcl instalation at home with a beocenter 9500 as master, and four different link room (2 MCL 2 passives) and 2 MCL2AV with MCL2P.
I want to install a beosystem 2300 in one of my link room. it will function as a slave. Is it possible.
I imagine two systems, wich one is the best:
Just plug the aux exit of the 2300 in the MCL2AV aux input. So I suppose my 2300 music could be ear in this room only( through the MCL2AV and amplified with the MCL2P ) and when the 2300 is OFF I can use the room as a standart ink room....is that corect ?
Now, is there a way to plug directly the 2300 on a slave mode on my MCL system ? So I will not need the MCL2AV and his IR
(I have no TV nowhere)
Thanks for your knowledge....I found a brochure about havind the 2300 on a slave mode, but no description of how to do the conections and how to set it.
