Latest post 08-12-2011 6:18 AM by Carolpa. 3 replies.
Page 1 of 1 (4 items)
  • 08-11-2011 9:58 AM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    A.Aux and Apps
    I have downloaded the new software.  I am using media:connect as a renderer and server.
    I have my BM5 connected ONLY via ML to the network.  There are no speakers directly connected to it.
    When I use the iPhone/iPad as a Server, the BM5 will turn on and show that music is playing.  .but no sound?
    I take it from this that when using the BM5 as a renderer there must be speakers connected to it?
    Anyone have any experience with this?
    I'm ready for something new that I actually want to buy!
  • 08-11-2011 12:22 PM In reply to
    Re: A.Aux and Apps
    I do not think that speakers need to be connected to the BM5. I have a BS5/BM5 connected by Masterlink to a BV 10 and a BV 7. Both tvs have speakers connected to the tv. I can control music with an app on my iPhone and iPad in both rooms, through speakers connected to each tv. I do not have much experience with MediaConnect as I could not get it to work at all for me. I have been using eLyric.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 08-11-2011 8:49 PM In reply to
    Re: A.Aux and Apps
    I am also able to use iPhone and iPad as server and the system plays the music without speakers being connected to the Beomaster 5. I have not done that much, however. Just did it to see if it worked and do not remember which app I used for that. I am traveling now or I would check it.
  • 08-12-2011 6:18 AM In reply to
    Re: A.Aux and Apps
    I doubt if it is with solemnly a BM5 at all possible.
    Does the BM5 shows AUX in the start-up menu? If not so, I would say it will be impossible to connect a smart phone simular to the way it is now possible on the Beosound 5!
