Latest post 08-14-2011 10:23 AM by Søren Mexico. 7 replies.
Page 1 of 1 (8 items)
  • 08-11-2011 8:26 AM
    • lewist
    • Not Ranked
    • Joined on 08-11-2011
    • Posts 5
    Beocenter 2600
    Hi Everyone, I am new to Beoworld,
    I have a Beocenter 2600 its a lovely unit it has 2 Beovox s35 speakers it has been working fine since I brought in last year second hand but all of a sudden it has started to play up the problem is with the Volume the trouble only seems to occur on Right Channel. The balance is level between the 2 channels but I find my self having to put the Volume to 3.5 - 4 on the number scale to get the bass driver to be level with the left channel and every now and then then you turn the volume up or down you can hear a crackle from the right channel or you have to turn the volume up and down until the bass on the right channel wants to work again.
    I have had it into the Repair shop a few times about this issue and they have checked it all and said they can find nothing wrong with it. Unless I am going totaly mad and imagining its doing it!!!
    When it was in the repair shop last it had a new belt put on the cassette deck and a full service but only having it back 6 weeks the same problem with the volume has now come back and it is now starting to become annoying.
    Any help or advice welcomed :)
    Lewis
    Filed under:
  • 08-11-2011 8:31 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2600
    Welcome to Beoworld !
    Try swapping the left/right loudspeakers (cables) to see if the problem is with the
    speakers or the Beocenter.
  • 08-11-2011 8:41 AM In reply to
    • lewist
    • Not Ranked
    • Posts 5
    Re: Beocenter 2600
    Hi Martin,
    Thank you for your reply i have just tried what you said and the problem is still their so I think the problem must be with the Beocenter itself
  • 08-11-2011 9:41 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beocenter 2600
    Do you mean that the problem is still in the same speaker or in the same Beocenter channel ?
  • 08-11-2011 10:01 AM In reply to
    • lewist
    • Not Ranked
    • Posts 5
    Re: Beocenter 2600
    The Speakers seem fine its deffinatly the right channel on the beomaster that is having the problems.
  • 08-11-2011 10:19 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beocenter 2600
    There can be countless reasons for this.
    Most likely are bad contacts, either in the pushbuttons or the sliders, aged capacitors
    and a faulty volume potentiometer.
  • 08-11-2011 12:40 PM In reply to
    • lewist
    • Not Ranked
    • Posts 5
    Re: Beocenter 2600
    Hi Martin,
    Thank you for your reply once again if the problem gets worse I will take it back to the repair shop and point those points out although I do think its the potentiometer. All I think the man has done is clean all the controls. But its not doing to badly considering its age.
    Thank you for all your kind help.
    Lewis
  • 08-14-2011 10:23 AM In reply to
    Re: Beocenter 2600
    lewist:
    Thats what we dont like here, we restore to nearly perfection, and then we can enjoy them for many years to comeLaughing
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
