1st March February 2012
Latest post 08-12-2011 6:07 AM by Carolpa. 7 replies.
08-11-2011 8:23 AM
ajames
- Joined on 05-04-2007
- Posts 275
Another question
I have a BV Avant RF 32 connected by Masterlink to a BS3000 and four penta speakers are plugged into the Avant. If I select an Audio Source the TV Screen goes blank - what I want to do is be able to have the TV screen on whilst listening to Audio - is there an option setting I need to program them for? I know that I can press the AV button - but the thing I want to watch is on the V.Aux socket and as I have to do list to get AV and V.Aux I can't seem to do it.
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
ajames
- Posts 275
Hi - it worked on those but not on A.Aux which is where my ipod is plugged into - I'll try again though tonight - if that works that's the problem solved
Andrew
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
Yes, there is no AV - A.AUX. Try AV - A.TAPE (A.MEM). Works at least with my BS9000.
Or try with BL1000: AV - SHIFT - RADIO.
Stefan
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
ajames: Hi - it worked on those but not on A.Aux
... use / buy a BeoLink 1000 and press "AV"; "SHIFT"; "RADIO"
Carolpa
- Posts 440
on a BS3000 use:
AV Phono
AV Tape (= AV A.Mem)
or with a BL1000
AV SHIFT RADIO (= AV A.Aux)
ajames
- Posts 275
Hi, thanks I've got it working if if I do AV then A.Aux - but can;t find AV Phono or AV Tape on my Beo 4 - it's the one with DVD and no light button - It doesn't appear on the add list - I seem to remember you have to configure it somehow for different audio and video masters - anyone know how I do this?
Carolpa
- Posts 440
does the Beo4 has an AV shown in the list (or can you add this item)?
List until AV is shown in display, than press A.Tape (or A.Mem depending on your Beo4)
to add an item on a Beo4:
press simultanious STBY and List.
press List until you get "ADD?" in the display; press GO
press List until you see the item to add (it's "blinking"); press GO
the item is ADDED
Page 1 of 1 (8 items)
