Latest post 08-11-2011 10:34 AM by OKF. 3 replies.
Page 1 of 1 (4 items)
  • 08-10-2011 3:59 PM
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    Does the Config Tool 4.11 work with Win 7 (64) or Mac?
    appreciate a feedback
    Best regards Oliver
  • 08-10-2011 8:09 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Does the Config Tool 4.11 work with Win 7 (64) or Mac?
    Win 7 (32) - YES
    The application is able to run on a Win 7(64) PC ,
    but it's the driver for Beo5/6, that will not work with 64 bit versions of Windows
    >>  No driver >> no contact to the remote control!
    Win 7 (64) - NO
  • 08-11-2011 10:26 AM In reply to
    You can get the config tool  working on a win 7 64 bit machine by installing and running win XP virtual machine within Win7 which is a free download. Then installing and running the config tool within the XP VM environment
    Saves having a seperate laptop for the CT software!
    Cheers
    Steve
  • 08-11-2011 10:34 AM In reply to
    • OKF
    • Posts 204
    Thanks, yes I have Win XP installed under Paralles but it is always some hassle with the USB devices with the virtual machines but I will have to go that path then.
    Best regards Oliver
