Latest post 08-19-2011 3:18 PM by Stoobietoo. 4 replies.
Page 1 of 1 (5 items)
  • 08-10-2011 5:12 AM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Which Freeview box for Beovision 5
    Got a customer who has the beovision 5 non hd, at the moment controls sky plus box, but he wants to have a frreeview box connected so he watch that on beovision 1 upstairs, anybody know which box will work without have to get the software upgraded!!
    Paul
  • 08-10-2011 7:03 AM In reply to
    Re: Which Freeview box for Beovision 5
    kai:
    Paul
    My BV5 was pre-freeview, so I finished up getting an HDR1 which already had the later STB module (rather than pay £200 for a B&O call-out and module change.)  The freeview boxes listed in the early to mid 2000's were the Panasonic TU 20 or 30 (or such similar number- listed in other posts I've made.)
    You can only get that particular box on the second hand market, although if you delve around on the Lintronic website you might be able to identify a later available Panasonic model that has the same codes.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 08-10-2011 1:53 PM In reply to
    I would recommend updating the sw and use an icecrypt 5000. The Panasonic TU CT20/30 are now scarce and since the transmitter updates in Oct 2010 they no longer work as they can find all of the multimplexes. For £35 tuner and £80 stb chip fitted it will save you and your client time and lots of hassle, trust me as I have been there! The B&O option is amazing but quite costly for a retro fit
    Stuart
  • 08-11-2011 6:26 AM In reply to
    w5bno123:
    I have three, all working and all updated. They do need to pick-up a software update at the right time and we did initially have programmes scrambled and in the wrong order in Oct 2010. Here in the North West (where we went digital many years ago) there was a big problem when the North Wales transmitters seemed to overwhelm the Winter Hill signal at many locations (and because the N. Wales signals were earliest in the frequency list when retuning). So whenever we do a retune/ update, it's always a case of pulling the aerial lead out until the STB search is halfway through, and then all the correct transmissions are picked-up and sorted by the software.
    Depending on the dealer call-out charges, buying or even upgrading a used HDR1 (or later recorder capable of being taken into the dealership) has got to be better than paying £200+ for a home visit just for the STB chip. The only draw back is having to select the recorder on the Beo4, and then hit the yellow button to go to the STB.
    Graham
  • 08-19-2011 3:18 PM In reply to
    When you go into the setup menu and choose STB on the AV socket of choice it will give you a list that your controller is capable of using
    This from the user manual -
    (I turned the TV on using TV not DTV)
    > Press MENU to call up the main menu.
    > Press 3 to call up the Setup menu.
    > Press 4 to call up the Connections menu (5 if a
    motorised stand is installed).
    > Press n to select a socket.
    > Press m or p to step through the list of available
    equipment types until you fi nd what you have
    connected. Select None if nothing is connected.
    > When you have selected your equipment types,
    press GO to store your settings
    or press EXIT to
    leave all menus without storing.
    I have just followed those instructions to be sure it works and the list comes up. I get a choice of 50 boxes. Below is what I have on my list and I beleieve it is the original software in my non HD BV5. (The list was emailed to me by my BEO Repair technician so I didn't need to sit in front of the TV and type it all here lol)
    Software - West Europe 4.01
    1. Amstrad SKY HD I
    2. DIGIFUS. FRT100
    3. DIGIF. FRT-101T
    4. DIGIFU. FVRT100
    5. ECHOSTAR 2200
    6. HOMECHOICE
    7. HOMECHOICE PVR
    8. HUMAX DTT-4100
    9. HUMAX PVR 9200T
    10. Sony Playstation 3
    11. NOKIA 9850T
    12. NOKIA 212T/9470
    13. PACE 4000 NTL
    14. PACE SKY+
    15. PACE TWIN DIGIT
    16. PAN. TU-CT20/30
    17. PANA. TU-CTH100
    18. SAGEM ICD 60-04
    19. SAGEM ITD 4410
    20. G Sci Atl DVR
    21. SA Exp 8300 TW
    22. Thomson SkyHD
    23. THOMSON DHD4000
    24. THOMSON DTI35x
    25. Kreatel IP-STB 1760
    26. CANALdigital NL
    27. CANALdigital B+
    28. CANAL+ Thomson
    29. HUMAX CI-5100C
    30. HUMAX PR-HD1000
    31. HUMAX HDCI-2000
    32. HUMAX CI8100PVR
    33. HUMAX F1-VACI
    34. MOTORO. DVi5000
    35. Philips DCR 1211/18
    36. Philips DSR7005
    37. REBOX RE-1250CO
    38. SAMSUNG DCB9401
    39. SAMS. DCB-H360R
    40. SAMSUNG SMT1x00
    41. Samsung DCB-P850RS
    42. TELENET DBAD101
    43. TF5000PVR
    44. TF5800PVR
    45. SKY DIGITAL
    46. Apple Remote
    47. indi 5800C
    48. TF4000PVR
    49. STARHUB HD
    50. Humax IPVR 9200C
    Hope that helps
    Stoobie
