Latest post 08-29-2011 8:56 PM by grillomex. 9 replies.
Page 1 of 1 (10 items)
  • 08-09-2011 1:06 PM
    Newbie on site, I feel like a child once again
    Hey Beoworld, Im so excited to join, I just recently purchased a pair of Boevox pentas, still trying to figure out which are they, I II or III, hopefully someone can help, did I metion I picked them up for $200? thats right. I have a speaker repair guy refoaming the midranges and cant wait to hook them up to a Beomaster 5500, any helpfull information you can share with this new B&O fan i would appreciate.
    thank you again and cant wait to keep on buying vintage equipment
  • 08-09-2011 1:19 PM In reply to
    Re: Newbie on site, I feel like a child once again
    Welcome to Beoworld, use the search function, who search will findBig Smile
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 08-09-2011 2:25 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    grillomex:
    Welcome to Beoworld.
    The BeoVOX penta's were passive speakers & only one incarnation were produced which would make them MK1's I suppose. It was the BeoLAB (active/powered) penta's which came in MK's 1,2 & 3.
    Chris.
  • 08-09-2011 3:00 PM In reply to
    Quite a difference as pointed out between Beovox and Beolab Pentas. If there is a grey box at the base, it is a lab. A Beovox is easy to connect - two pin DIN speakers cables are all you need.
  • 08-09-2011 8:49 PM In reply to
    Hey Soren, are you in Mexico city? I grew up there until I was 17 and then moved to USA and here ever since, thats is so cool if you are from there let me tell you
  • 08-09-2011 8:52 PM In reply to
    thank you for the replies guys, this ones are gray on the base and they have red & black standard connectors plus it came with a set of original speaker cables with a 4 pin connector, so are this the Boevox, or Beolab? and do you think it was a good purchase?
  • 08-09-2011 9:04 PM In reply to
    grillomex:
    Ve mi avatar amigo, si, vive en la ciudad, y otra vez bienvenido
  • 08-10-2011 10:34 PM In reply to
    Speakers are back from re-foaming, I noticed a craking noise when I turn on the BM5500 and a humming noise but then it goes away and they sound awasome, anyone here knows what is the crack nad humming comming from?, I'm trying to search on it but not getting much...
    please help
  • 08-22-2011 5:11 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    The cracking noise will probably be down to a bad solder joint somewhere in the Beomaster. I had a similar symptom with my Beomaster 8000 and this was te solution (several dry joints on the amplifier circuit board)!
    As always, a new set of caps should be contemplated!
    Jacques
  • 08-29-2011 8:56 PM In reply to
    Thank you chartz... I will send it for repair soon, right now im just loving listening to my new vinyl finds, next week I'll sent it to get serviced....
