Hi all.
I have a Beovision 7-32 TV (monitor edition without the integrated DVD and seemingly with an integrated surround-card) a Beocenter 2 and the following speakers: Beolab2, 2 x Beolab 8000 and 2 x Beolab 6000.
The technician who installed the TV for me, connected all speakers into one connection (maybe two - they are both labelled Power Link Centre) on the left side back panel of the BV7. I notice that there are numerous speaker-connectors on the right hand side back panel... None of them are used.
The problem is that the Beoloab 2 doesn't function as a sub anymore. At best, the sound is equivalent to the sound from a loudspeaker with treble only... The Beolab 2 functioned very well as long as I had the same speakers, same stereo and a Beovision 3-32. When I used the Beovision 3-32, the speakers were connected directly to the TV.
I think a challenge is that this monitor-edition doesn't have an integrated centre speaker...
The question is: How can a I connect (and setup the TV) the speakers correctly, so that the Beolab 2 functions properly and the other speakers (at least the Beolab 8000's) function as front/side/back speakers? If I have to first switch on the TV and then switch on the speakers via the remote (chose speaker setup or something), that's fine. I'm just tired an disappointed that the Beolab 2 doesn't work... It's been like this for two and a half years....
Please help... Thanks.
